Panneaux solaires https://www.t5calif.info/forum/viewtopic.php?f=8&t=191 |
Page 14 sur 15 |
Auteur: | davidl986 [ 12 Jan 2011 16:03 ] |
Sujet du message: | |
Il existe ça comme panneau rigide http://www.accessoires-camping-car.fr/p ... 0&pid=4182 et des souples http://www.batterie-solaire.com/PBSCCat ... tID=431068 et surtout le regulateur de charge indispensable http://www.ecosolaire.com/produit/126/R ... R1515.aspx |
Auteur: | FEBU [ 13 Jan 2011 21:58 ] |
Voici quelques renseignements pris aupres du vendeur de ces panneaux solaires: http://stores.ebay.es/flex-solarpanel cela concerne les 2 panneauw en 60 watts= 120w P: Hello can I cut the solar panel on the width(1 cm,0.03 foot/0.39 inch to 1.5cm,0.05 foot/0.59 inch), or is it possible to order shorter in width? what is the material, glass or Teflon? Sincerely R: Thanks intresting in our products, better not cut the finish solar panel products ,but order the shorter in width ,we can make customize. this solar apnel material : Laminated with oxide aluminum+EVA+Silicon cells+2 layers of EVA+Tedlar. What is your best size ? just let us know ,we will calculate out what is the watts for you,thanks. Hello my best size is 880 or more/555/2.5 mm What is the watt, and the price for two pannel? Does the panel is flexible on the width? Thank you for your answer Sincerely If you want width in 555mm ,the length can be 920mm,you can get 60watts . the longer length,shorter side will make the panel more flex, another note : the solar panel back up aluminum material ,it has small connection box on the front of panel ,if you want to make the connection box on the back is ok too ,just let us know ,we will make it . price is the same with the listing you see :http://cgi.ebay.com.hk/ws/eBayISAPI.dll?ViewItem&item=250744740884 ,any more question please feel free let me help ,thanks. En bref il est possible d'avoir des panneaux en 920/555/2.5mm comme ceux montés sur ce T5 Espagnol: http://www.furgovw.org/index.php?topic=173998.0 Cordialement |
Auteur: | djibouthéziens [ 21 Jan 2011 19:38 ] |
Sujet du message: | eh viva, Espagna! |
Bravo, Febu. C'est ça que je veux voir! Enfin une solution alternative au PZUAB 40 et économique en regard de la qualité et des puissances proposées. Je pense pousser plus loin mes investigations. L'installation espagnole que tu proposes en lien est vraiment propre, je la convoite déjà. Merci encore pour le suivi et les idées de tous. |
Auteur: | loupescadou [ 01 Fév 2011 19:39 ] |
Bonsoir, Ce que Febu propose semble éffectivement intérréssant. Dans la mesure ou cette installation correspondrait au cahier des charges de plusieurs d'entre nous, pourrais tu, febu, nous en donner les détails? merci |
Auteur: | luc64 [ 13 Avr 2011 11:00 ] |
Sujet du message: | panneau solaire portable |
en cherchant un equivalent au fameux PZUAB j'ai trouvé cela : http://cgi.ebay.fr/Portable-Solar-Power ... 27b373fbe1 Ca semble pas mal.Votre avis ? |
Auteur: | st38 [ 14 Avr 2011 07:07 ] |
Pas mal pour la portabilité en effet, c'est multi usage par contre attention ça vient des US et là bas ils sont en 110 V, pas sur que le convertisseur livré fasse 110 et 220, à vérifier! |
Auteur: | luc64 [ 14 Avr 2011 11:03 ] |
L'option 110 ou 200 est prevue |
Auteur: | luc64 [ 30 Avr 2011 10:16 ] |
Sujet du message: | panneaux solaires portales |
je viens de recevoir mes panneaux solaires commandés a taiwan (en 8 jours!) http://cgi.ebay.fr/Portable-Solar-Power ... 27b373fbe1 le pack semble sympa. (j'ai bien eu le convertisseur avec une sortie en 220V) Photos et commentaires aprés essai....... |
Auteur: | fozainne [ 30 Avr 2011 14:01 ] |
Sujet du message: | Prise allume cigare |
Salut, La prise allume cigare à l'arrière à droite charge quelle batterie ? Merci Florian |
Auteur: | AJC [ 30 Avr 2011 18:23 ] |
Si tu as un Calif, les deux auxiliaires (sous la penderie et sous le siège conducteur), pour le Beach je ne sais pas. PS. Renseignez votre signature, elle nous permet d'orienter nos réponses... ciblées... |
Auteur: | opticalifornia [ 02 Mai 2011 18:12 ] |
Sujet du message: | Panneau solarflex |
Les panneaux de FEBU de provenance SUNFLEX sur ebay ont l'air pas mal. Cela me tente bien d'être autonome en énergie avec ces panneaux là et un montage comme l'ont fait les espagnols sur le site furgovw. Je vais y réfléchir plus avant.... |
Auteur: | xdelore [ 16 Juin 2011 15:49 ] |
Sujet du message: | Re: panneaux solaires portales |
luc64 a écrit: je viens de recevoir mes panneaux solaires commandés a taiwan
(en 8 jours!) http://cgi.ebay.fr/Portable-Solar-Power ... 27b373fbe1 le pack semble sympa. (j'ai bien eu le convertisseur avec une sortie en 220V) Photos et commentaires aprés essai....... Salut Luc64, alors quel retour sur ces panneaux solaires? Tu les branches sur quoi exactement? sur la prise allume-cigare derrière la porte coulissante? Ailleurs? a+ xavier |
Auteur: | luc64 [ 21 Juin 2011 12:30 ] |
Sujet du message: | un petit retour |
packaging tres complet. la batterie supplementaire est une option sympa.(2Ah) pour le branchement du panneau sur le calif, j'ai essayé sur la prise allume cigare pres de la banquette.... C'est pas une reussite. J'ai du faire une betise. Le fusible que j'avais monté sur ma ligne a claqué..... Depuis je mesure que 10 W sur mes panneaux de 40W. (Si ma methode est bonne mais j'ai un doute) Je suis preneur pour une methode fiable de test et pour un bon scheme de cablage !!! Depuis ce pemier essai soit le temps ne s'y prete pas soit j' ai pas de dispo pour reessayer |
Auteur: | xdelore [ 21 Juin 2011 15:01 ] |
Sujet du message: | Re: un petit retour |
luc64 a écrit: C'est pas une reussite. J'ai du faire une betise. Le fusible que j'avais monté sur ma ligne a claqué.....
Bonjour Luc64, tu l'avais monté où ton fusible? As-tu essayé de brancher directement sur les batteries? Il me semble que sur les schéma espagnol ils viennent se mettre direct sur les batteries? xavier |
Auteur: | opticalifornia [ 10 Sep 2011 16:00 ] |
Sujet du message: | Quelle puissance pour le panneau solaire? |
Je vais me lancer à faire un montage panneau flexible + collage sur le toit. J'hésite quant à la puissance à choisir, est ce que 100W c'est suffisant pour un usage de camping itinérant standard (sauvage). Qu'en pensez vous? |
Page 14 sur 15 | Heures au format UTC + 1 heure |
